djpiecka1
Příspěvek od djpiecka1 »
CAUKO.Aj ja by som sa chcel vediet viac info
Win:W0L0AHL4865128265
Astra H r.v.2006 1.6. 77kw
Autoscanner Profi Czech U581 - CAN OBD-II, live data
mach00
Příspěvek od mach00 »
2 berus:
VIN: W0L0AHL3565046084
W0L: General Motors
0: VOZIDLO BEZ ZVLÁŠTNÍ ÚPRAVY
A: Astra Platform
H: 2004 Platform Generation
L35: Estate
6: 2006
5: Antwerp
046084: SERIAL NUMBER
Kód modelu: 0TV35
Kód balení: LD61
Datum výroby: 10.10.2005
Typ motoru: Z19DT
Sériové číslo motoru: 4668446
Čalounění: XXVE
Výbava: 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 79U = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AM4 = ZADNÍ DĚLENÉ OPĚRADLO SEDADLA,SKLOPNÉ,VLASTNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BNN = ÚLOŽNÁ SCHRÁNKA,LOŽNÝ PROSTOR BNR = LIŠTA KRYCÍ DVEŘE VNITŘEK,SVĚTLÁ BURL BNU = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ,SVĚTLÁ BURL BS7 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,DVĚ BARVY BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ BW4 = S CHROMOVOU LIŠTOU BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU COB = VYROBENÉ V ANTWERPÁCH 2 CR7 = PRO MAĎARSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDH = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,PRAVÉ,LEVÉ DDI = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E94 = KRYT ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LPM = VZNĚTOVÝ MOTOR Z19DT[LPM] MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS2 = PRO VARIABILNÍ POSILOVAČ ŘÍZENÍ NT4 = EMISE,EEC 05 OHD PXE = TEXTILNÍ ČALOUNĚNÍ,SCALA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T61 = PRO SYSTÉM DENNÍCH SVĚTEL T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE TM7 = BATERIE,60AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ U07 = HOUKAČKA,TROUBA U3F U55 U65 = REPRODUKTOR,5 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCK = RÁDIO AM/FM STEREO,HLEDÁNÍ,MCD,ETR,TLUMENÍ UD7 = ČIDLO PARKOVACÍHO SYSTÉMU UEQ = ODPOJOVAČ AKUMULÁTORU UJ3 V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ VDR VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0L = ELEGANCE Z1F = RYCHLOMĚR KM/H Z1O = PRO MAĎARSKO Z1X = BARVA,JEDEN POVLAK
mach00
2 djpiecka1:
VIN: W0L0AHL4865128265
W0L: General Motors
A: Astra Platform
L48: 5-DV. SEDAN
6: 2006
5: Antwerp
128265: SERIAL NUMBER
Kód modelu: 0TN48
Kód balení: IZS1
Datum výroby: 15.2.2006
Typ motoru: Z16XEP
Sériové číslo motoru: 20GT6776
Čalounění: XXVM
Výbava: 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 4DU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJ7 = PRO BEZP. VAK ŘIDIČE, SPOJEZDCE A BOČNÍ VAK AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED BL5 = LIŠTA KRYCÍ DVEŘE VNITŘEK,STŘÍBRNÁ BLB = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,STŘÍBRNÁ BRE = IDENTIFIKAČNÍ KRITICKÝ BOD 2006 1/2 MR C60 = KLIMATIZACE CR7 = PRO MAĎARSKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q = ENJOY ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 G61 = 4 ŠROUB UPEVNĚNÍ KOLA JM4 = BRZDOVÝ SYSTÉM,KOTOUČ-PŘEDNÍ/BUBEN-ZADNÍ K60 = ALTERNÁTOR,100AMP KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LHD = ŘÍZENÍ LEVÉ LJ7 = MOTOR Z16XEP[LJ7] M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N52 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA PY3 = KOLO,DISKOVÉ,OCELOVÉ,61/2JX16 QGF = PNEUMATIKY,205/55 R 16-91H QQ5 = PRO VELKÉ NÁHRAD.KOLO T9W = OBKLAD,VNITŘNÍ,TABITA TN6 = BATERIE,55AH TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ U3F U71 = ANTÉNA,ÚPLNÁ,STŘECHA UEQ = ODPOJOVAČ AKUMULÁTORU UF8 = TROJITÝ INFORMAČNÍ DISPLEJ LCD - DATUM/ČAS/TEPLOTA UJ3 URA = SPÍNAČ OVLÁDÁNÍ RÁDIA UW5 = REPRODUKTOROVÝ SYSTÉM 6,BASE VDR VG9 = OCHRANNÍ VOSK W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XB2 = PRO MAĎARSKO XJ9 = PRO MAĎARSKO Z1F = RYCHLOMĚR KM/H Z1O = PRO MAĎARSKO
inka
Příspěvek od inka »
Ahojky,
pls , potřeboval bych juknout na W0L0XCE7584088267 - /Opel Meriva/
Díky moc.
REGISTRAČNÍ ČÍSLO: WL-GR 499 Datum výroby: 20071016 Značka: Opel Vauxhall VIN: W0L0XCE7584088267 Kód modelu: 0ZC75 Kód balení: JP62
Typ motoru: Z17DTR
Sériové číslo motoru: 01664716
W0L:General Motors
X:Corsa
C:Meriva
E75:Monocab (E75)
8:2008
4:Zaragoza
088267:SERIAL NUMBER
18I = OBLOŽENÍ VNITŘNÍHO PROSTORU TMAVĚ UHLOVÁ 18X = BARVA ČALOUNĚNÍ SEDADLA TMAVĚ UHLOVÁ 18Y = OZDOBNÁ LIŠTA DVEŘNÍHO PANELU,BAREVNÁ 4XU = VNĚJŠÍ BARVA,VIZ SEZNAM BAREV V ÚVODĚ KATALOGU 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE A32 = ELEKTRICKY ŘÍZENÉ OKNA,PŘEDNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AG4 = PŘEDNÍ SEDADLO,LEVÉ,REGULÁTOR VÝŠKY,RUČNÝ AQ6 = PŘEDNÍ SEDADLO,NASTAVITELNÁ OPĚRKA AU0 = ZÁMEK DVEŘÍ,S DÁLKOVÝM OVLÁDÁNÍM AWF = S ÚLOŽNOU KAPSOU AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ B40 = ZAKRÝVAJÍCÍ LOŽNÝ PROSTOR,PEVNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BNG = DVEŘNÍ KRYCÍ LIŠTA VNITŘEK,UHLOVÁ MAZE BNN = ÚLOŽNÁ SCHRÁNKA,LOŽNÝ PROSTOR BYF = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘEK,UHLOVÁ MAZE C32 = PRO SYSTÉM QUICKHEAT C60 = KLIMATIZACE C76 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,ZADNÍ ČTVRT,KOMFORTNÍ A DVOJITÁ ČTECÍ C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU C97 CT3 = PRO NĚMECKO CT3 D11 = POPELNÍKY,PŘEDNÍ A ZADNÍ D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY D75 = KLIKA ÚPLNÁ VNĚJŠÍ D91 DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO DDU = ZRCÁTKO,SESTAVA DJ9 = ZRCADLO,ELEKTRICKÉ A VYTÁPĚNÉ,ŠIROKÉ,PRAVÉ,LEVÉ DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) ECA = KLÍČ FX3 = PROGRAM ELEKTRONICKÉ STABILITY FXB = POMĚR NÁPRAVY 3.65 G62 = 5 ŠROUB UPEVNĚNÍ KOLA GDI = TEXTILNÍ ČALOUNĚNÍ,PUNCH/ELBA JBG = PÁKA RUČNÍ BRZDY,CHROM S VYSOKÝM LESKEM JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KG9 = ALTERNÁTOR,140A KIS = KRYTKA,RUKOJEŤ ŘADICÍ PÁKY,S CHROMOVÝM KROUŽKEM LHD = ŘÍZENÍ LEVÉ LUB = VZNĚTOVÝ MOTOR Z17DT/A17DT MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N33 = PRO NASTAVITELNÝ SLOUPEK ŘÍZENÍ N45 = VOLANT,TŘI PAPRSKY NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OFZ OHA = MÍSTNÍ GM Z EUROPE OHA PG1 = KOLO,VOZOVKA,OCEL,6JX15 QLF = PNEUMATIKY,185/60 R 15-88H T67 = BATERIE,70AH T74 T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TEC TGR TRP = RÁMEČEK,RADIOPŘIJÍMAČ TTX = PRO POMOCNÝ KONEKTOR RÁDIA U3A U55 U68 = INFORMAČNÍ POČÍTAČ UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UD3 = SNÍMAČ INDIKÁTOR PARKOVACÍHO ASISTENTA VZADU,VAR 2 UJ3 UW6 = REPRODUKTOR,6 UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH VG9 = OCHRANNÍ VOSK VHC = ZÁCHYTNÝ HÁK PRO NÁKLAD,OPĚRADLO ZADNÍHO SEDADLA VK8 = DRŽÁK,BRÝLE W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W2N = PÍSMO,LATERAL, VYNECHEJTE W3F = POTAH,ZAROVNANÝ,KOLO,VARIANT 7 W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WTR = DOČASNÁ OPRAVA PNEUMATIKY XA3 = OPEL XG3 = PRO NĚMECKO XL8 = PRO FREKVENCI 433 MHZ XM5 = ZAŘÍZENÍ,ÚROVEŇ 1 Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
palo14
Příspěvek od palo14 »
Ahoj
Môžem aj ja poprosiť o info.
Ďakujem
VIN: WOLOAHM7572067812
REGISTRAČNÍ ČÍSLO: ME-AH 1090 Datum výroby: 20061108 Značka: Opel Vauxhall VIN: W0L0AHM7572067812 Kód modelu: 0QS75 Kód balení: LF61
Typ motoru: Z17DTH
Sériové číslo motoru: 17188669
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
M75:Monocab (Zafira)
7:2007
2:Bochum
067812:SERIAL NUMBER
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE 79U = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AE4 = PRO SPORTOVNÍ SEDADLA AF8 = KONTROLA ZAMYKÁNÍ POSTRANNÍCH DVEŘÍ,OCHRANA PROTI KRÁDEŽI AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ AP7 = VSTUP BEZ KLÍČE A SYSTÉM STARTU AV4 = DĚLENÉ ZADNÍ SEDADLO AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B70 = KRYT PRAHU DVEŘÍ B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BA9 = CHLADNIČKA BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ BLN = LIŠTA KRYCÍ DVEŘE VNITŘEK BLUDIŠTĚ,CHROMOVÁ BLP = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,MATNĚ CHROMOVANÁ BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C32 = PRO SYSTÉM QUICKHEAT C68 = PRO ELEKTRONICKOU KLIMATIZACI C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CE4 = OSTŘIKOVAČ SVĚTLOMETU CT3 = PRO NĚMECKO CT3 D18 = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,CHROMOVANÉ KRUHY D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA) E94 = KRYT F52 = PODVOZEK SE SPORTOVNÍ ÚPRAVOU FE4 = SYSTÉM PRO SPECIÁLNÍ JÍZDU A JÍZDNÍ VLASTNOSTI (IDS+) FW7 = POMĚR NÁPRAVY 3.83 FX3 = PROGRAM ELEKTRONICKÉ STABILITY FZ3 = PRO ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY (STABILITA PŘÍVĚSU) G62 = 5 ŠROUB UPEVNĚNÍ KOLA JF5 = POUŽITO SPOLU S PEDÁLEM SPORT ZE SLITINY JL9 = ABS K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU K34 = REGULÁTOR RYCHLOSTI KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA KB5 = ASISTENT ROZJEZDU DO KOPCE KC7 = ELEKTRICKÁ ZÁSUVKA,ZADNÍ SEDADLO KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA KCN = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 3.POLOHA KG9 = ALTERNÁTOR,140A LHD = ŘÍZENÍ LEVÉ LRD = VZNĚTOVÝ MOTOR Z19DTH MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU MZ4 = PŘEVODOVKA S RUČNÍM ŘAZENÍM M32 (WR) N35 = VOLANT,SPORT,KŮŽE NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NS1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE NT4 = EMISE,EEC 05 OHC OIF P38 = KOLO,VOZOVKA,HLINÍK,5 PŘÍČEK,71/2JX18 PHQ = TEXTILNÍ ČALOUNĚNÍ,ALPHA STŘÍBRNÁ/ELBA QNA = PNEUMATIKY,225/40 R 18-92W R2L T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T67 = BATERIE,70AH T96 = SVĚTLO DO MLHY PŘEDNÍ T9M = ČALOUNĚNÍ ELBA TGR TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ TSQ = OSVĚTLENÍ INTERIÉRU DELUXE TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA TTO = RÁDIO CHLADICÍ SYSTÉM U07 = HOUKAČKA,TROUBA U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ U71 = ANTÉNA,ÚPLNÁ,STŘECHA UAJ = GRAFICKÉ INFORMACE - BARVA UCL = RÁDIO AM/FM STEREO,HLEDÁNÍ,DVD,NAVIGACE,ETR,TLUMENÍ UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH UJ3 UJ9 = INDIKÁTOR PODHUŠTĚNÍ PNEUMATIKY UJC = SPÍNAČ SPORTOVNÍ REŽIM UK6 = POUŽITO U OVLÁDÁNÍ RÁDIA A ZDÍŘEK SLUCHÁTEK U ZADNÍHO SEDADLA UWA = PŘÍPRAVA PRO MOBILNÍ TELEFON,S OVLÁDÁNÍM HLASEM A SYSTÉMEM BLUETOOTH V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU V3D = NOSIČ ZAVAZADEL VOLNÝ STŘEŠNÍ,ČERNÝ V4M = VYBAVENÍ 5-STAR,SADA NCAP VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ VG2 = OCHRANNÍ VOSK, VYNECHEJTE VK8 = DRŽÁK,BRÝLE VNF = ODPOJOVAČ BATERIE VQ9 = ODMONTOVATELNÁ SPOJKA ZÁVLEKU VU2 = STŘEDOVÝ PŘÍSTROJ NA PANELU,CHROMOVANÁ MATT W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y W7P = ŠTÍTEK,SPORT WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO WBG = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,GPS WTS = SADA,PNEUMATIKA,OPRAVA PNEUMATIK,INTEGROVANÉ VYBAVENÍ XA3 = OPEL XG3 = PRO NĚMECKO Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z0F Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ ZQ8 = UŽITO SPOLU SE SPORTOVNÍM PODVOZKEM
jour
Příspěvek od jour »
Zdravim, potrebujem surne zistit cislo tohto dielu. Je to mechanizmus sklapania laktovej opierky, po nemecky to je "Schaniereinheit"
Dakujem!
Solik
Příspěvek od Solik »
Asi se to skládá ze dvou kousků (viz. obrázek), ale prodávají to i jako sadu:
jour
Příspěvek od jour »
Dik Solik! Moc si mi pomohol. Vies mi aj hodit cislo dielu oznaceneho ako 24? To je to co potrebujem.
