Mike.S
Příspěvek od Mike.S »
power2 píše:Smím taky prosit? Dííky. W0L0AHL0875090309
W0L:General Motors
A:Astra Platform
H:2004 Platform Generation
L08:3-DV. SEDAN
7:2007
5:Antwerp
090309:SERIAL NUMBER
vyrobena: 3.1.2007
první RZ: HH-QS7894
čalounění: XXVM
motor: Z16XER
č. motoru: 20JJ0348
výbava:
2AU = VNĚJŠÍ BARVA,VIĎ SEZNAM BAREV V ÚVODĚ KATALOGU MODELŮ 2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ 80I = VNITŘEK-ČERNÝ 80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ 80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO A88 = OPĚRKA HLAVY,PŘEDNÍ SEDADLO,AKTIVNÍ AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE AJ0 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,DVA AM4 = ZADNÍ DĚLENÉ OPĚRADLO SEDADLA,SKLOPNÉ,VLASTNÍ AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ BD8 = LIŠTA,CELK.,STŘEŠNÍ,V BARVĚ KAROSERIE BNS = LIŠTA KRYCÍ DVEŘE VNITŘEK,SATÉNOVÁ STONE BPI = LIŠTA PŘÍSTROJOVÉ DESKY,SATÉNOVÁ STONE BRG = IDENTIFIKAČNÍ KRITICKÝ BOD 2007 1/2 MR BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE C60 = KLIMATIZACE C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM CT3 = PRO NĚMECKO D75 = KLIKA ÚPLNÁ VNĚJŠÍ DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ DDU = ZRCÁTKO,SESTAVA DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ DP6 = TĚLESO DT4 = POPELNÍK A ZAPALOVAČ CIGARET DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ E4Q ECA = KLÍČ FX1 = KONEČNÝ POHON NÁPRAVY 3.94 FX3 = PROGRAM ELEKTRONICKÉ STABILITY G62 = 5 ŠROUB UPEVNĚNÍ KOLA JL9 = ABS K09 = ALTERNÁTOR,120AMP K34 = REGULÁTOR RYCHLOSTI KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA LDE = Z16EXR,A16XER ZÁŽEHOVÝ MOTOR LHD = ŘÍZENÍ LEVÉ M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE NT4 = EMISE,EEC 05 OHA = MÍSTNÍ GM Z EUROPE OHA PHP = TEXTILNÍ ČALOUNĚNÍ,TABITA/ELBA QGF = PNEUMATIKY,205/55 R 16-91H QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16 QQ5 = PRO VELKÉ NÁHRAD.KOLO T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ T96 = SVĚTLO DO MLHY PŘEDNÍ T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU T9W = OBKLAD,VNITŘNÍ,TABITA TN6 = BATERIE,55AH TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ TRP = RÁMEČEK,RADIOPŘIJÍMAČ TSQ U3A U55 U66 = REPRODUKTOR,7 U68 = INFORMAČNÍ POČÍTAČ UAC = INFORMAČNÍ PANEL LCD - VÍCEFUNKČNÍ UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3 UD7 = ČIDLO PARKOVACÍHO SYSTÉMU UJ3 V90 = PŘÍPRAVA PRO UPEVNĚNÍ NÁKLADU VDR VG2 = OCHRANNÍ VOSK, VYNECHEJTE VOD = MŘÍŽKA CHLADIČE,MŘÍŽOVANÁ,ČERNÁ,S CHROMOVANOU TYČÍ W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU W4Y WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO XA3 = OPEL XG3 = PRO NĚMECKO XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI Z0F = PRO NĚMECKO Z1F = SENZOR,OVLÁDACÍ SYSTÉM,LEVÝ
Old cars:
Škoda 120L
Škoda Felicia Combi LXi
Actual car:
Mike.S
myslíš? to je cena za jeden :| :mrgreen:
jinak za OPC se platí dost, ale to znáš už z Gčka 8-)
Old cars:
Škoda 120L
Actual car:
jj takže přes litřík no snad najdu na netu levněji,opel nechám jako poslední možnost koupě :mrgreen:
Mike.S
nebo si počkej až bude mít astrule 7 let :mrgreen: a pak máš u Opelu slevu 30% na ND, ale musíš si to u nich nechat namontovat 8-)
Old cars:
Škoda 120L
Actual car:
dík,ale tak dlouho se mi nechce čekat :mrgreen:
Q-čko
Příspěvek od Q-čko »
bubo píše:Nádržky asi stejné nejsou ! Ta pro check control bude mít právě tu díru pro senzor . Co vím , tak senzor snímá přes stěnu nádržky výšku hladiny kapaliny , takže žádný plovák tam asi není.
Ta díra není durch do nádržky - je to prolisek dovnitř a to čidlo je v suchu . Číslo zasílám na fotu , snad přečteš - trochu jsem to zvýraznil .
Na Astraforu - RU to popisují :
http://www.astra-h.ru/antifrize_sensor.html
ahoj toto je ta nadrzka s cidlom?dakujem nemozem to nikde inde najst kde sa da zohnat aj s cidlom hm
číslo záslepek nárazníku?
corsaczek
Příspěvek od corsaczek »
Originál boční clony na Caravan - zadní dveře? Díky!
Příspěvek od Pepino_GH »
Pokud jsem dobře hledal:
Samothe - 1400771 L, 1400772 P - ks á 622,- s DPH v základu pro 3 dv.
Corsaczek - 6732019 - 3.268,- s DPH
hmm solidní pálka,tak nic :mrgreen:
