řekni si o info podle svého VIN zde
Morfeus70
Příspěvek od Morfeus70 »
ahoj, jsem čerstvým majitelem, také tedy poprosím o info, moc děkuji W0L0AHL35A2106103
Opel Astra H Kombi (L35), 1.6, 85kW, r.v. 09/2010, motor Z16XER, VIN: W0L0AHL35A2106103, najeto cca 138t km
Typ motoru Z16XER
Seriove cislo motoru 20PL7594
Kod datum 22052010
Kod rizeni GM XXVX
W0L:General Motors
0:VOZIDLO BEZ ZVLD�STN� ÚPRAVY
A:Astra Platform
H:2004 Platform Generation
L35:Estate
A:2010
2:Bochum
106103:SERIAL NUMBER
20S = BARVA STEHŮ,HVĚZDNĚ STŘÍBRNÁ
2J1 = KOBEREC,VNITŘNÍ PODLAHA,STANDARDNÍ
80I = VNITŘEK-ČERNÝ
80X = VNITŘNÍ VYBAVENÍ KAROSÉRIE - ČERNÉ
80Y = LEM OPLECHOVÁNÍ DVEŘÍ,ČERNÝ
A14 = SKLO,BOČNÍ OKNO,ZADNÍ,ZBARVENÉ
A51 = PŘEDNÍ PROHLOUBENÉ SEDADLO
AH3 = PŘEDNÍ SEDADLO,ŘIDIČ,RUČNÉ NASTAVENÍ
AJT = PRO PŘÍPRAVU K MONTÁŽI BEZPEČNOSTNÍ SÍTĚ
AQ0 = OPĚRKA HLAVY,ZADNÍ SEDADLO,VINYLOVÝ POTAH,DVA,KRAJNÍ
AY0 = VZDUCHOVÝ POLŠTÁŘ,STŘECHA,PŘEDNÍ
B70 = KRYT PRAHU DVEŘÍ
B75 = KRYT PROSTORU PRO ZAVAZADLA ÚPLNÝ
B86 = LIŠTA STRANA KAROSÉRIE BAREVNÁ
BKX = S POLOLESKLOU KRYCÍ LIŠTOU Z MATNÉHO CHROMU
BS9 = TĚSNĚNÍ PRIMÁRNÍ,DVEŘE,SPODNÍ
BSO = IDENT.EFEKTIVNÍ BOD CON.
BSS = LIŠTA KRYCÍ DVEŘE VNITŘEK,CHROMOVANÁ MATT ČÁSTEČNĚ LESKLÁ
BUF
BW4 = S CHROMOVOU LIŠTOU
BW7 = DEKORACE VNĚJŠÍ SLOUPEK APLIKACE
C32 = PRO SYSTÉM QUICKHEAT
C68 = PRO ELEKTRONICKOU KLIMATIZACI
C95 = SVÍTILNA,ÚPLNÁ,STROPNÍ,S DVOJITOU ČTECÍ LAMPIČKOU
CE1 = STÍRAČ,PŘEDNÍ,IMPULSOVÝ SYSTÉM
CE4 = OSTŘIKOVAČ SVĚTLOMETU
CT3 = PRO NĚMECKO
CT3
D75 = KLIKA ÚPLNÁ VNĚJŠÍ
DD8 = PRO VNITŘNÍ ZRCÁTKO CITLIVÉ NA SVĚTLO
DDG = ZRCADLO,ELEKTRICKÉ,PRAVÉ,LEVÉ
DDU = ZRCÁTKO,SESTAVA
DGZ = SCHRÁNKA V PŘÍSTROJOVÉ DESCE DĚLÍCÍ PŘEPÁŽKA
DH6 = STÍNÍTKO PROTI SLUNCI,S OSVĚTLENÝM ZRCADLEM,PRAVÉ,LEVÉ
DP6 = TĚLESO
DT4 = POPELNÍK A ZAPALOVAČ CIGARET (KUŘÁCKÁ VÝBAVA)
DVA = SDRUŽENÝ PŘÍSTROJ,ČERNÝ,ČERNÉ KRUHY SE STŘÍBRNOU HORNÍ ČÁSTÍ
E4R = PRODEJNÍ BALÍK SADA-COSMO
E94 = KRYT
ECA = KLÍČ
FX1 = KONEČNÝ POHON NÁPRAVY 3.94
FX3 = PROGRAM ELEKTRONICKÉ STABILITY
G62 = 5 ŠROUB UPEVNĚNÍ KOLA
GBJ = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
JL9 = ABS
K09 = ALTERNÁTOR,120AMP
K34 = REGULÁTOR RYCHLOSTI
KA1 = PRO VYHŘÍVANÁ PŘEDNÍ SEDADLA
KCL = TRUBKA TOPENÍ,ZADNÍ SPOLUJEZDEC 2.POLOHA
LDE = Z16EXR,A16XER[LDE] ZÁŽEHOVÝ MOTOR
LHD = ŘÍZENÍ LEVÉ
M25 = RUČNÍ PŘEVODOVKA,5 RYCHLOSTNÍ,F17 TYP
MM3 = POUŽITO SPOLU S RUČNÍ PŘEVODOVKOU
N34 = VOLANT ÚPLNÝ TROJPŘÍČKOVÝ S KOŽENÝM POTAHEM
NC0 = ZAŘÍZENÍ,EVROPSKÁ UNIE
NT4 = EMISE,EEC 05
OEZ
OFM
OHB
OMO
PXF = LEM,ALFA/VINYL
QGF = PNEUMATIKY,205/55 R 16-91H
QL5 = KOLO,VOZOVKA,HLINÍK,10 PŘÍČEK,61/2JX16
QQ5 = PRO VELKÉ NÁHRAD.KOLO
T2Q = REFLEKTORY,AUTOMATICKÉ ZAPÍNÁNÍ/VYPÍNÁNÍ
T6K = PANEL VYBAVENÍ,VNITŘNÍ,VINYL
T96 = SVĚTLO DO MLHY PŘEDNÍ
T9P = DEKORACE TMAVÁ,TĚLESO SVĚTLOMETU
TN7 = BATERIE,66AH
TPV = MŘÍŽKA CHLADIČE,ČERNÁ,S CHROMOVANOU TYČÍ
TR0 = OSVĚTLENÍ VNITŘNÍHO PROSTORU,STŘEŠNÍ,ZADNÍ,KOMFORTNÍ A DVOJITÉ ČTECÍ
TRP = RÁMEČEK,RADIOPŘIJÍMAČ
TSP = SVÍTILNA,ÚPLNÁ,VNITŘNÍ VLASTNÍ
TSQ = OSVĚTLENÍ INTERIÉRU DELUXE
TT2 = SVĚTLOMETY SMĚROVÉ,VYSOKÁ INTENZITA VÝBOJKA,TLUMENÉ XENONOVÉ,DÁLKOVÉ XENONOVÉ/HALOGENOVÉ
TTX = PŘÍVOD POMOCNÉHO KONEKTORU VÝBAVY RÁDIA
U3A
U55
U66 = REPRODUKTOR,7
U68 = INFORMAČNÍ POČÍTAČ
UAG = GRAFICKÁ INFORMACE - JEDNOBAREVNÁ
UCH = RÁDIO AM/FM STEREO,HLEDÁNÍ,CD,ETR,TLUMENÍ,MP3
UD7
UJ3
V3E = DRŽÁK ZAVAZADEL VOLNÝ STŘEŠNÍ,STŘÍBRNÝ
VG2 = OCHRANNÍ VOSK, VYNECHEJTE
VGB = STŘEŠNÍ NOSIČ ZAVAZADEL,ELOXOVANÝ
VK8 = DRŽÁK,BRÝLE
VVH = STŘEDOVÝ PŘÍSTROJ NA PANELU,UHLOVÁ PIANO
W1Y = PRO OVLÁDÁNÍ RADIOPŘIJÍMAČE NA VOLANTU
W4Y
WBE = VYBAVENÍ PŘIJÍMACÍHO ZAŘÍZENÍ,RÁDIO
XA3 = OPEL
XG3 = PRO NĚMECKO
Y67 = POŽADUJE PŘI OSAZENÉM SERVISNÍM DISPLEJI
Z0F = PRO NĚMECKO
Z1F = RYCHLOMĚR KM/H
Morfeus70
moc děkuji
Jo,jo ;)
RHS
Příspěvek od RHS »
Taky poprosím
W0L0AHM7562010257
W0L:General Motors
A:Astra Platform
M75:Monocab (Zafira)
6:2006
2:Bochum
010257:SERIAL NUMBER
4AU = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
80I = VNITŘEK-ČERNÝ
A23 = PŘEDNÍ SKLO,REFLEXIVNÍ TEPLO
A33 = ELEKTRICKY ŘÍZENÉ OKNA,ZADNÍ
AE4 = PRO SPORTOVNÍ SEDADLA
AH4 = PŘEDNÍ SEDADLO,POHON,6-CESTNÝ RUČNÍ
AHA = S NASTAVITELNOU OPĚROU BEDERNÍ PÁTEŘE
AV4 = DĚLENÉ ZADNÍ SEDADLO
AY9 = OPĚRKA HLAVY,ZADNÍ,VINYL,STŘED
BA9 = CHLADNIČKA
BF8 = ÚLOŽNÁ SCHRÁNKA,PŘEDNÍ SEDADLO,PRAVÉ
BLK = KRYCÍ LIŠTY PŘÍSTROJOVÉ DESKY,ŘADA KOVOVÁ STŘÍBRNÁ
BLM = LIŠTA KRYCÍ DVEŘE VNITŘEK,ŘADA KOVOVÁ STŘÍBRNÁ
CU3 = PRO FRANCII
CU3
D70 = PŘEVODOVÝ POMĚR ROZVODOVKY 2.77
DA7 = LOKETNÍ OPĚRKA PŘEDNÍHO SEDADLA,VLEVO
DP6 = TĚLESO
E94 = KRYT
ECA = KLÍČ
FZ3 = ZDOKONALENÝ ELEKTRONICKÝ PROGRAM STABILITY
JL9 = ABS
K13 = POUŽÍVÁ SE S FILTREM PEVNÝM ČÁSTIC VE VÝFUKOVÉM SYSTÉMU
KC8 = ZÁSUVKA,VÝSTUP POMOCNÉHO NAPÁJENÍ
LHD = ŘÍZENÍ LEVÉ
LRD = VZNĚTOVÝ MOTOR Z19DTH[LRD]
M36 = AF40-6 AUTOMATICKÁ PŘEVODOVKA
MM1 = POUŽITO SPOLU S AUTOAMTICKOU PŘEVODOVKOU
NR1 = PRO REDUKOVANOU DRÁHU HŘEBENOVÉ TYČE
NT4 = EMISE,EEC 05
OHB
PBF = LEM,ALPHA/MONDIAL
QL6 = KOLO,VOZOVKA,HLINÍK,5 PŘÍČEK,61/2JX16
T9S = SVÍTILNA ÚPLNÁ,VNITŘNÍ,PŘEDNÍ DVEŘE
TM7 = BATERIE,60AH
TTB = OSVĚTLENÍ VNITŘNÍ,STŘEŠNÍ, ZADNÍ KOMFORTNÍ A DVOJITÉ ČTECÍ,3. ŘADA
U07 = HOUKAČKA,TROUBA
U3D
U55
UAH = DISPLEJ INFOTAINMENT,GRAFICKÝ INFORMAČNÍ DISPLEJ (GID),VAR2
UEC = SNÍMAČ INDIKÁTOR AUTOMATICKÉ RECIRKULACE VZDUCHU
UEQ = ODPOJOVAČ AKUMULÁTORU
UH0 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,LH
UJ3
UJC = SPÍNAČ SPORTOVNÍ REŽIM
ULR = ZAPALOVAČ CIGARET,ZADNÍ,LOKETNÍ OPĚRKA
URA = SPÍNAČ OVLÁDÁNÍ RÁDIA
UW6 = REPRODUKTOR,6
V2T = NOSIČ,ZAVAZADEL,STŘEŠNÍ,S PRÁŠKOVOU ÚPRAVOU
V4M = VYBAVENÍ 5-STAR,SADA NCAP
VFE = NÁRAZNÍK PŘEDNÍ A ZADNÍ,OCHRANNÝ VÝLISEK,BAREVNÝ
VG9 = OCHRANNÍ VOSK
VK8 = DRŽÁK,BRÝLE
VNF = ODPOJOVAČ BATERIE
W4Y
XA3 = OPEL
XK2 = PRO FRANCII
Z0W = PRO FRANCII
Z0W
RHS
Příspěvek od RHS »
Děkuji
milos
Příspěvek od milos »
Zdravím pánové,
můžete mi prosím dát nějaké info také na Insignii?
W0LGS87K791043660
Díky ;)
Astra H caravan 1.7cdti, r.v. 2007
Insignia ST 2.0cdti, r.v. 2009
W0L:General Motors
G:Insignia
S8:S35 (Estate) (Sport / SRI)
7:Active (manual) Belts, driver & passenger front & side & curtain air bags optional rear side & occupant sensors
K:A20DTJ (LBX)
7:KONTROLN� C�SLICE
9:2009
1:Russelsheim
043660:SERIAL NUMBER
01A = BARVA ČALOUNĚNÍ SEDADLA ČERNÁ
1AB = BARVA ČALOUNĚNÍ PANELU DVEŘÍ ČERNÁ
2A2 = DVEŘNÍ KRYCÍ LIŠTA VNITŘEK,ČERNÁ PIANO
3A5 = LIŠTA PŘÍSTROJOVÉ DESKY VNITŘNÍ ČERNÁ PIANO
4AA = BARVA ČALOUNĚNÍ INTERIÉRU ČERNÁ
6Y4 = NÁHRADNÍ KOLO A PNEUMATIKA,VYNECHEJTE
A69 = OMEZOVAČ NAPÍNAČE BEZPEČNOSTNÍHO PÁSU, PŘEDNÍ
A6B = PRO SEDADLO S ČÁSTEČNĚ MANUÁLNĚ NASTAVITELNOU VODICÍ LIŠTOU V 6 SMĚRECH
A6D = PRO SEDADLO S ČÁSTEČNĚ MANUÁLNĚ NASTAVITELNOU VODICÍ LIŠTOU V 6 SMĚRECH
A70 = ZÁMEK,BEZPEČNOSTNÍ PÁS S NAPÍNACÍM MECHANISMEM
AEF = ELEKTRICKY OVLÁDANÁ OKNA, EXPRESNÍ NAHORU/DOLŮ
AFA
AHS = 4CESTNÁ AKTIVNÍ OPĚRKA HLAVY
AJH = PRO PŘÍPRAVU PRO BEZPEČNOSTNÍ SÍŤ ZA PRVNÍ ŘADOU
APG = PRO 4CESTNOU ELEKTRICKY OVLÁDANOU BEDERNÍ OPĚRKU
APH = PRO 4CESTNOU ELEKTRICKY OVLÁDANOU BEDERNÍ OPĚRKU
ATG = OVLÁDÁNÍ ZÁMKU S DÁLKOVÝM VSTUPEM
AXG = PRO DOTYKOVÉ OTVÍRÁNÍ OKNA
AY5 = OPĚRKA HLAVY,ZADNÍ,TEXTIL,STŘED
B9K = KRYT PRAHU DVEŘÍ
BAH = IMOBILAJZER,ELEKTRICKÝ,VARIANT 2
BSI = IDENT.EFEKTIVNÍ BOD CON.
C2B = SVÍTILNA,ÚPLNÁ,VNITŘNÍ,PŘEDNÍ PODLAHA
C59 = TRYSKA,ZADNÍ ODVZDUŠŇOVACÍ OTVOR
C99 = VYPÍNAČ AIRBAGU SPOLUJEZDCE
CT3 = PRO NĚMECKO
CT3
D31 = ZRCÁTKO ZPĚTNÉ VNITŘNÍ
D61 = KRABICE NA ULOŽENÍ,STRANA ŘIDIČE
D7C = POLICE PŘÍSTROJOVÉ DESKY BOČNÍ
DA1 = LOKETNÍ OPĚRKA ZADNÍHO SEDADLA,ÚLOŽNÁ
DBU = PODLAHOVÁ KONZOLA VPŘEDU S POSUVNOU LOKETNÍ OPĚRKOU
DK6 = VNITŘNÍ STROPNÍ KONZOLA
DP6 = TĚLESO
DWE = POUŽÍVÁ SE S RUČNÍM SKLÁPACÍM ZRCADLEM
E94 = KRYT
EA1 = KAPSA,OPĚRADLO PŘEDNÍHO SEDADLA,LH
EA2 = KAPSA,OPĚRADLO PŘEDNÍHO SEDADLA,RH
EAD = TEXTILNÍ ČALOUNĚNÍ SEDADLA, VITESSE
EPA = KAPSA, SEDÁK PŘEDNÍHO SEDADLA, VLEVO
EPB = KAPSA, SEDÁK PŘEDNÍHO SEDADLA, VPRAVO
F45 = TRVALE VARIABILNÍ TLUMENÍ PODVOZKU VE SKUTEČNÉM ČASE
FBD = TEXTILNÍ ČALOUNĚNÍ DVEŘÍ ATLANTIS
FX4 = KONEČNÝ POHON NÁPRAVY 3.35
GBG = VNĚJŠÍ LAK, VIZ KATALOG MODELŮ, ÚVOD, TABULKA LAKŮ
GNA = VÝBAVA PODVOZKU, SESTAVA PŘEDNÍ VZPĚRY
GNC = VÝBAVA PODVOZKU, ZADNÍ NÁPRAVA, 4 TÁHLA
J60 = PRO UŽITÍ S 16" BRZDOVÝM SYSTÉMEM
J71 = ELEKTRONICKÁ RUČNÍ BRZDA
JF5 = POUŽITO SPOLU S PEDÁLEM SPORT ZE SLITINY
K3S = BATERIE,75AH
KB5 = ASISTENT ROZJEZDU DO KOPCE
KD4 = POUŽÍVÁ SE S ELEKTRICKOU ZÁSUVKOU V PŘEDNÍ KONZOLE
KPA = POUŽÍVÁ SE S ELEKTRICKOU ZÁSUVKOU V PŘEDNÍ KONZOLE
KRH
KRJ = PRO MULTIFUNKČNÍ AUDIO OVLÁDÁNÍ
LBX = A20DTJ[LBX] VZNĚTOVÝ MOTOR
LHD = ŘÍZENÍ LEVÉ
M53 = SPOJKA BLOKACE ŘAZENÍ
MDE = PRO KRAJNÍ OKENNÍ CHROMOVANOU LIŠTU
MF3 = RUČNÍ PŘEVODOVKA,6RYCHLOSTNÍ (M32-6 WR)
N35 = VOLANT,SPORT,KŮŽE
N37 = SLOUPEK ŘÍZENÍ, NASTAVITELNÝ, DOSAH A SKLON
NE9 = EMISNÍ SYSTÉM EEC 09
NV7 = POSÍLOVAČ ŘÍZENÍ,PROMĚNLIVÉ ÚSILÍ
OHA = MÍSTNÍ GM Z EUROPE OHA
PMA = POUŽITO S PRODLOUŽENÍM POLŠTÁŘE SEDADLA
PMB = POUŽITO S PRODLOUŽENÍM POLŠTÁŘE SEDADLA
Q02 = KOLO 18X8,HLINÍK, 5 DVOJITÝCH PAPRSKŮ
QKD = PNEUMATIKA ALL 245/45R18-96W
T61 = PRO SYSTÉM DENNÍCH SVĚTEL
T74
T79 = PRO ZADNÍ MLHKOVKY
T83 = PRO AUTOMATICKÉ OVLÁDÁNÍ ZAPÍNÁNÍ-VYPÍNÁNÍ SVĚTLOMETŮ
TR6 = ROVNÁNÍ REFLEKTORŮ,RUČNÉ
TT4 = REFLEKTORY,HALOGEN
U18 = RYCHLOMĚR ÚPLNÝ KM/H
U65 = REPRODUKTOR,7
UDC = PRO MONOCHROMATICKÉ INFORMAČNÍ CENTRUM ŘIDIČE DOT MATRIX
UDK = GRAFICKÉ INFORMACE - BARVA
UH1 = VÝSTRAHA BEZPEČNOSTNÍHO PÁSU,RH
UK3 = VOLANT,ŘÍZENÍ,PŘÍSTUP
ULS = OVLÁDÁNÍ ZÁMKU, SLOUPEK ŘÍZENÍ
URC = PRO PODVOZEK FLEXRIDE
US3 = DIVERZITNÍ ANTÉNA
USR = PRO USB PORT
UXX
V83 = PROHLÁŠENÍ K VOZIDLU - ORGANIZACE ECE
VY7 = PÁKA PŘEVODOVKY,KŮŽE
W4Y
W7Z = ZAŘÍZENÍ,ZIMA
WRA
WRB
WTR = DOČASNÁ OPRAVA PNEUMATIKY
XA3 = OPEL
XG3 = PRO NĚMECKO
XJ2 = NIŽŠÍ SPORTOVNÍ PODVOZEK
XL8 = PRO FREKVENCI 433 MHZ
Z0F = PRO NĚMECKO
Wirda
Příspěvek od Wirda »
Ahoj, mohl bych taky poprosit info? Jde mi hlavně o číslo motoru, abych podle toho mohl koupit spojkovou sadu. Je jich pro moji motorizaci vícero druhů. Díky moc ;)
W0L0AHL3552001552
